Electro Mechanical Repairs Division
Bowers Electricals Ltd undertake many Electro Mechanical Repairs, which compliment our manufacturing, repair & rewind facilities. We have substantial machine shops where we can produce most mechanical components by our experienced mechanical engineering team.Machining & Balancing
We have fully equipped Machine shop facilities available for all types of machining, milling, welding, radial drilling, metal spraying & balancing.
This section also has one of the largest centre lathes available within the industry, allowing machining of large armatures, shafts and rotors. Re-keying and re-shafting of rotors are carried out on a routine basis, along with specialist motor repairs and motor part manufacture. This division also manufactures many component parts required by our Transformer & Switchgear divisions.
Traction
Bowers Electricals Ltd are the vehicle and infrastructure engineers to the Great Orme Tramway at
Llandudno and have re-engineered and manufactured new pulleys and rollers for the haulage rope system. Repairs, overhaul and remanufacture are carried out to all types of bogies, Traction Motors & Transformers, including re-tyring of traction wheels and pressing facilities up to 50 tons. Bowers have developed a close liaison with the Heritage Rail Organisation and also have maintenance contracts looking after Power assets within the Traction manufacturing industry.
Gear Boxes, Pumps and Fans and associated equipmentWe offer full service and overhaul, both in-house and on-site, for repair and service of Gear boxes, pumps and fans and associated equipment, including installation.
Fabrication
Our fabrication facilities include production of all types of Power & Distribution Transformer tanks, Substation base frames, oil disconnection & bus bar chambers, Containerised Substation modification and LV Switchboard enclosure for both indoor & outdoor use.
